Compression test results!
Buy one 20oz bottle of techron and add it to your fuel tank then drive it. This will clean everything up to the point you will get real compression readings. Sorry if you guys don't like my advice but i have lots and lots of experience to back me up.
my 9:1 motor with a turbo cam, was reading in the 100-120 PSI on that gauge, a stock C6 Z06 reads about 150, and a z06 with 11.5:1 CR reads about 170.
You could buy some GM Top Engine Cleaner and run that through the system and maybe clean up any carbon build up in the valves.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Average readings on a Stock LS motor that I have seen have been in the 180 - 190 range.
Your Compression numbers are "Normal" and are within acceptable range.
So if my numbers seem acceptable, what would cause it to burn oil, and put out a big blue cloud under WOT, am I looking at valve seals for sure?
I'll betcha stock LS1 in excellent shape will measurse in the 160 range same with the LS6, the ZO6 maybe in the 175 range.
