Which seats?
Old Oct 21, 2009 | 03:29 PM
supersick99z's Avatar
Default Which seats?
I got some Comp Cam Single 918's and have everything but the seats. Can I reuse stock seats or what do I need?
Old Oct 21, 2009 | 03:39 PM
ND2RACE's Avatar
Comp 918s are a direct replacement spring, when I had my first set some time ago I reused the stock seats, seals, retainers, and locks. You'll be fine.
Old Oct 21, 2009 | 03:46 PM
01ssreda4's Avatar
absolutely correct. Direct drop in.
Old Oct 21, 2009 | 06:27 PM
even in a car with 103,xxx?
Old Oct 21, 2009 | 08:20 PM
outkast6991's Avatar
seats aren't really a wear item. unless there is something wrong with them they should be fine
Old Oct 21, 2009 | 11:46 PM
appreciate it guys!
Old Oct 22, 2009 | 11:29 AM
01ssreda4's Avatar
The seats, for the record, are integrated into the valve stem seal. When replacing valve springs you can easily ****** the valve seals off and replace them. Original GM seals are pretty cheap. 8 seals are black, that's for the intake valves, and 8 seals are brown, those are for the exhaust valves.
Old Oct 22, 2009 | 11:52 AM
Yeah I knew that I figured I'll probably get a set of stock seats since they are cheap anyways that way they are newer too.
