Paging Terry @ Patriot
Old Dec 7, 2003 | 11:02 PM
Drew778's Avatar
Well, I pressurized the cylinder and it seems to be holding, if I had a bent valve the air leaking out would be obvious right?
With the new spring should be up and running
Old Dec 7, 2003 | 11:06 PM
Beast96Z's Avatar
Yes, leaking air would either be coming from the throttle body or the exaust. Usaully better to use a gauge, but you should have nothing to worry about.
Old Dec 7, 2003 | 11:47 PM
Z O SICK's Avatar
Terry is a stand up guy indeed! Just got a set of stage II LS6 heads from him and they rock! Great price and great service what else could you ask for?
Tony
Old Dec 7, 2003 | 11:57 PM
SScam68's Avatar
hey man take it easy on those stangs!! LOL
Hope your up and running asap!
Frank
Old Dec 8, 2003 | 12:12 AM
CAT3's Avatar
Restricted User
Andrew, did Terry mention he will Ovrnight them? Would be nice to get your engine back together, and my trans issue and someone else, new forged bottom in. May want to call first thing their time tomorrow morning.
Old Dec 8, 2003 | 12:35 AM
Drew778's Avatar
Hey Frank
Here yah go
http://www.insaynestangs.com/images/FSC.WMV
http://www.insaynestangs.com/images/DrewvsNakaRace.WMV
Cat, I e-mailed him, it coming one way or another.
I'm just happy it's just the springs!!!
Old Dec 8, 2003 | 05:35 AM
Hannibal's Avatar
Originally Posted by Retsik
Terry, since I also have a set of the original springs - should I be concerned here?
I WOULD spend the money to replace them.
Old Dec 8, 2003 | 07:27 AM
TVWilkes's Avatar
Default Springs
I will send you a set also.Forward me you shipping address.Thanks, Terry
Old Dec 8, 2003 | 07:29 AM
Retsik's Avatar
WOW!! I'll send a PM right away!
Old Dec 8, 2003 | 07:54 AM
v8maro's Avatar
If you break a spring, please don't drive it, the inner spring is only there to hold the valve up and prevent P/V damage. I had the same problem w/5k miles on my springs, if you have the old ones, probably should replace them.
I need to get the replaced old ones off of my car asap, well, once it's fixed =\, but I still have them on there with the cleared rockers. Still worried about them tho.
-Steve
Old Dec 8, 2003 | 09:59 AM
Whistler's Avatar
Sawzall and Welder Mod
Another example of Terry and Partiot standing behind what they sell. I installed a set of their stage 2 5.3 heads on a friend'd car and the engine burned oil, smoking out the tailpipe at idle. All tests indicated valve seal problems.
Terry was helpful in both providing new seals and getting them installed. Not to say their product is faulty, but the law of avereges says if you sell hundereds of a particular item, there will be a few that will have problems.
The new seals fixed the problem, the car is now 100% and there's a lot to be said for Patriot's customer service.
Old Dec 8, 2003 | 02:07 PM
  #32
skunk50's Avatar
I have to ask this, and that is....what about the cost for labor for replacing the old springs (for those who don't know how to do it)? Will Patriot pay for all or part of the cost of labor?
Old Dec 8, 2003 | 02:29 PM
  #33
BergerMan's Avatar
If you can change your own spark plugs, then you can change out your valve springs. It should only take about 2-3 hours max. to change all 16. If you don't know how, then learn. that is what this forum is all about, getting your hands dirty and learning about YOUR car. I don't know of any performance part from anyone with a warranty that covers labor.
Old Dec 8, 2003 | 04:34 PM
  #34
Drew778's Avatar
What spring tool to you guys use?
I had a More tool and that thing suck, it was to soft and would spread apart.
How much is a good tool?
Old Dec 10, 2003 | 07:58 PM
  #35
skunk50's Avatar
true on the labor...i'm just wondering if there is a known defect with these springs that were shipped on the older batch of heads.
i can understand if one or two people get a defect and have to pay the labor cost, thus the risk of buying high performance parts.....but if many people are having problems, then i'd like to know if there will be any support for the cost of labor from the company?
and no, i probably wouldn't want to change the springs myself.
Old Dec 10, 2003 | 08:54 PM
  #36
TVWilkes's Avatar
The springs in question are no longer used.I have replacement springs,that will work with the original retainer,shims and locks.I can offer these when needed.At this time there is no help with labor.
Old Dec 10, 2003 | 09:27 PM
  #37
slyws6's Avatar
if anyone needs help with labor my buddy and I have devised a slick little tool that makes changing the springs MUCH MUCH easier than the tool More Performance sells for $129. We'd sell it for $25 for anyone that may need it. Also if your anywhere near Asheville , NC come on over and I'll change the springs out for ya for free, only on Terry's heads tho
-Sly
Old Dec 10, 2003 | 11:15 PM
  #38
ta12sec's Avatar
pp
I think I may have decided on who to buy my heads from...............
Old Dec 11, 2003 | 01:09 AM
  #39
Drew778's Avatar
Thanks Terry!!!
I got my spring today and installed them.
The only thing that wrorries me, is that they look just like the one's that broke
Old Dec 11, 2003 | 08:26 AM
  #40
TVWilkes's Avatar
They are not from the same manufacturer.The new ones are a little stronger,better material.Thanks, Terry
