LS-6 valves verses Oversized valves
Old 11-18-2009, 10:18 AM
b15nut's Avatar
On a side note I have a question about the valves. The LS6 valves are all sodium filled or always hollow intake and sodium exhaust? Been searching forever and cant find a straight answer. Thanks.
Old 11-18-2009, 11:13 AM
VeTTeMaNC486's Avatar
99 percent sure the intakes are hollow and the exhaust are sodium filled.
Interesting thread, does not seem like such a small change, esp. on the intake side would really be worth the valve train weight the larger, solid valves would add.
Subscribing.
Old 12-04-2009, 05:50 PM
omc8's Avatar
Yes its always been hollow intake and sodium filled exhaust, no evidence GM ever had a LS-6 sodium filled intake.
Old 12-07-2009, 05:24 PM
omc8's Avatar
tttt bump
Old 12-07-2009, 06:15 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
You can get larger than stock hollow valves. I was going to use hollow 2.04 and LS6 1.55 sodium filled valves in my last set of heads, but I ended up selling them. I think with your stock bore I would go with the LS6 valves combined with good headwork. A nice valve job, radius throat cut, and blend will pick up a lot of flow combined with the larger than the 5.3's stock valves.
Old 12-08-2009, 05:02 PM
omc8's Avatar
Interesting,who makes those 2.04 hollow intake valves, are they stock length?And thanks for the info.
Old 12-08-2009, 07:43 PM
FoFittyFoSS's Avatar
About valve shrouding, on big block chevrolets, sometimes the block itself is notched a little to help unshroud the intake valve. Has this been tried on any of the LS motors? I assume so or either it is not an issue. Just curious.
Old 12-09-2009, 08:42 PM
omc8's Avatar
I don't think its a issue with the 2.02 intake 1.57 exhaust even on small bore.Lets have a real expert chime in .
Old 12-10-2009, 10:07 PM
omc8's Avatar
bump to the top
Old 12-10-2009, 10:33 PM
printmanjackson's Avatar
get them cnc'd and a good valve job and call it a day. these heads respond good this.
Old 12-10-2009, 10:41 PM
Your're not an "Expert" what are you doing in here? LOL
Old 12-11-2009, 10:05 AM
  #32
no but I have slept in a Holiday Inn before
Old 12-12-2009, 05:12 PM
  #33
omc8's Avatar
Well Im going to get a room at the Holiday Inn and see if any this automotive wisdom will enlighten my thinking !
Old 12-16-2009, 08:59 PM
  #34
omc8's Avatar
Yes this would be the way to go ,but cnc is not in the budget for this build!
Old 12-17-2009, 02:40 PM
  #35
omc8's Avatar
bump to top
Old 01-10-2010, 12:40 PM
  #36
BowtieBoyAV's Avatar
Since it was briefly touched on, and partially answered, I figured I would contribute.
As mentioned, the reason for hollow intake valve stems is reduced mass.
The reason the LS6 exhaust valves are sodium filled is for reduced temperature (and thus ultimately durability).
Since intake valves inherently run much cooler than exhaust valves, there is no technical reason to sodium fill them. It would just be a wast of money.
Old 01-13-2010, 05:57 PM
  #37
omc8's Avatar
Good info on the sodium exhaust valves.
Old 02-01-2010, 04:58 PM
  #38
omc8's Avatar
Originally Posted by SLOC5LS6
subscribing.....I've only heard of a 2-3hp difference between 2.00/1.55 valves vs the 2.02/1.57 valves on a 3.9 bore
Originally Posted by Old SStroker
Plus or minus?
Can anyone expand on this ,I believe its a gain !
Old 02-02-2010, 05:11 PM
  #39
omc8's Avatar
Anyone know how much of a gain ?
Old 02-02-2010, 06:55 PM
  #40
XtraCajunSS's Avatar
Back-cut and valve job with the stock hollow stems. You won't be sorry. Been there, done that. The larger valves are useless on the stock bore. If you were building a 4.0" bore engine, the larger valve starts to shine a bit but I might still be temped to run the lighter valve. I have an LSK lobed cam in my DD CTS-V, it pulls like a SOB out past 7K... Of course, it does have a very simple but properly executed valvetrain setup...
Shane
Quick Reply: LS-6 valves verses Oversized valves
