Help broken extractor!
Old Oct 27, 2009 | 11:10 PM
M1T/A's Avatar
Default Help broken extractor!
Well to make it short i broke a head bolt 3 inches or so down in the block. After that i drilled it out and broke a ez out off in the bolt. Please help me cause nothing i have tried will drill through this extractor! Thanks
Old Oct 28, 2009 | 12:32 AM
mknight759's Avatar
your probably screwed those extractors are something serious you probably gonna have to bust the extractor out of there somehow someone else may have a better idear im sure your not the first good luck!!
Old Oct 28, 2009 | 01:12 AM
M1T/A's Avatar
I ground a good screwdriver to a piont and busted out alot of it, but whats left in there will not come out and it is just flattening every point i grind.
Old Oct 28, 2009 | 01:19 AM
M1T/A's Avatar
Anyone ever tried a diamond coated bit like northern tool sales? Surely diamonds are harder than this thing.
Old Oct 28, 2009 | 01:46 PM
Mumbles's Avatar
I had a similar experience with a broken motor mount bolt this past winter. Here is a link to the thread I started when it happened. I was looking for advice as well.
https://ls1tech.com/forums/generatio...ount-bolt.html
Eventhough I didn't get any initial responses, I kept it updated. Read post #2 and it will tell you what I did to solve this problem. Good luck, man.
Old Oct 28, 2009 | 05:05 PM
Paul57's Avatar
A carbide drill bit worked for me.
Isn't Northern Tool a lot like Harbor Freight...cheap...you get what you pay for, usually.
Old Oct 29, 2009 | 04:49 PM
M1T/A's Avatar
I have tried carbide titianium masonry and high speed bits nothing working so far. The bolt is three inches down so i cannot get my dremel on it.
Old Oct 30, 2009 | 01:15 AM
M1T/A's Avatar
Well i went to northern tools site and most of the products are name brand but the diamond drill bits are their house brand. I ordered some out of desperation will let you guys know how it turns out.
Old Oct 30, 2009 | 01:04 PM
BAD2000TA's Avatar
Is this on the LS1 block? You might want to avoid the aggravation and find a replacement block. I know, I know, that's not something you want to do. But, if you can't get it out or you damage the threads, it's all going to be a waste of time. LS1 blocks are now pretty cheap. Hell, I pick-up an 2004 LS6 short block (pistons, rods, crank) for $500.00. You might also consider an upgrade to an LS2 block. Just a thought. Good luck.
Old Oct 30, 2009 | 10:52 PM
M1T/A's Avatar
Ya a new shortblock is my final choice. I guess I am just too stubborn and proud to give up! Thanks man
Old Oct 31, 2009 | 07:47 AM
G Engines's Avatar
You could try to find a shop around with an edm machine they can get it out. It may not be cheeper than buying a block.
Old Nov 1, 2009 | 12:58 AM
M1T/A's Avatar
I found a company that can burn it out with a lazer but i gotta pull the motor so i figure if i am gonna pull it i might as well go back with more cubes. Maybe an lq9 shortblock?
Old Nov 1, 2009 | 02:24 AM
Thimble's Avatar
If you can find a 7/16" hole saw, it should be about the same dia as the head bolt hole...use it w/o the pilot bit, and basically core drill the broken bolt (and extractor) out.
From there, there are heli-coil repair kits available for the odd M11 head bolt thread.
I've not tried this, but have used the same technique on other applications. If your alternative is another block, it is worth a shot.
Old Nov 1, 2009 | 02:34 AM
M1T/A's Avatar
Sounds reasonable to me. I will try that if the diamond bit dont work. Great idea by the way!
Old Nov 1, 2009 | 07:17 AM
cutlass_455's Avatar
Make sure to soak that thing in some Fluid Film or something, help break it loose.
Old Nov 1, 2009 | 08:20 AM
DaveX's Avatar
Find someone with a large sinking EDM machine. That is about the only way your likely to get it out without damaging the threads.
I am a tool and die maker, and never use extractors. Once you break them you are screwed. Carbide will drill them, but you will be trying to drill into a jagged end and the carbide drill will walk and/or break also.
Old Nov 1, 2009 | 11:01 PM
M1T/A's Avatar
Been soaking it every night with marvel. What is fluid film? What is a edm machine?
Old Nov 1, 2009 | 11:14 PM
Mike94ZLT1's Avatar
EDM is the key. I broke off a bolt in the end of my crankshaft on my new stroker... then broke an EZ out trying to get it out. Luckily for me the motor was not in the car yet, but it was still a huge pain in the ***. I found a place that had an EDM machine and took it to them. $300 later the bolt was out... but it was worth every penny.
Old Nov 2, 2009 | 02:22 AM
M1T/A's Avatar
300 dollars plus the 100 i have spent trying to get it out so far i am ****** myself!
Old Nov 2, 2009 | 06:16 PM
Mike94ZLT1's Avatar
You're crying about spending $400 yet you're thinking about building a stroker? Perhaps you should rethink that, as you will spend at LEAST 12-15x that, without going crazy. Not trying to be a dick, but you need to know what you're getting yourself into.
