Broken Motor Mount Bolt
A couple days after twisting off the bolt, I started drilling into it with some cobalt bits. I couldn't get the best angle with my Dewalt Drill. The K Member was in the way to really get centered on the bolt. So I drilled as deep as I thought I could without getting into the threads. Next I drove a bolt extractor into the hole and began to turn it ccw into the bolt. I had a really good bite, and thought now was the time to put some muscle to it and get this bastard out. So I got a good grip and twisted that ****** hard. "SNAP!" Yeah thats right. I busted off the easy out in the bolt. So not only do I still have a bolt stuck in the block, but now a Hardened Steel bit. ****. I tried drilling at it. Nothing. So after a few days of asking friends, guys at work and anybody who'd listen, I was searching the net for ways to bust through an easy out and found a testimonial on a yachting website. A guy had a similar situation and he had used a Dremel with diamond tipped bits to eat the bolt/bit away. I thought what the hell, I'll give it a shot. The gentlemen claimed the stuck bolts were dust in like 5 min. Well my experience wasn't exactly 5 min. More like 5 hours each day for a couple days and 4 or 5 bits later, I had the easy out and bolt ground away enough I thought I could start drilling again. By this time I had an arsenal of drills borrowed and a 90* air powered one that really did the trick for fitting into the tight spot. Started drilling again and "ting." The tip of the easy out came flying out. YES! I then proceed with the 90 to drill completely through the bolt, progressively using larger bits. Then rather than risk busting off another extractor, I decided I would drill the bolt out as large as I could go and then use a tap to cut new threads. I stayed up until 3am last night working on this, but I'm happy to its done. The motor mounts were installed this afternoon with minimal fuss and now all thats left is to return everything to its spot in the engine bay and finally finish the exhaust. If everything goes well should have the project completed by Sunday. Wish us luck...
Any tips on the job you can give me? I had taken off the passenger mount when doing the oil pan, but I haven't tried doing the driver's side. It looks like there's even less room on that side. Do you think I should definately take off the driver's header or do you think I can work around it?
We did consider that option as a last resort, but decided if you're gonna do something, do it right and be done with it. This way it doesn't come back in the future to bite you in the ***. I've done two more poly mm installs since then without any trouble. It being a bitch the first time made the next couple times seem like a breeze.
