99 ls1
Old Oct 28, 2009 | 10:28 PM
kenracer's Avatar
Default 99 ls1
I have a 99 ls1 in a TransAm and when i start it up the lifters make noise for about 3 to 4 seconds. Oil and filter are new. Old oil was clean every time i have changed it. Car runs great and has about 40 psi oil press at idle hot. Got any ideas?
Old Oct 29, 2009 | 01:36 AM
mwatson185's Avatar
The noise is most likely piston slap. It is common and nothing to worry about.
Old Oct 29, 2009 | 10:59 PM
kenracer's Avatar
noise goes away too fast to be piston slap. I've had that in other ls1s. Is something bleeding down over time?
Old Oct 30, 2009 | 12:16 AM
Finkledbody's Avatar
Maybe there is piston slap after 3-4 seconds and you refuse to hear it. Maybe it starts out loud and it gets more quiet after 4 seconds. Get a video of it to so we can hear whats going on!!
Old Oct 30, 2009 | 06:47 AM
O2Form's Avatar
Mine has terrible lifter noise at start up too, if i run it hard then its really bad the next time i start it. After a oil change it really rattles, I have 40+ oil pressure at idle hot, car runs ok. Its more of a rattle than a tap in mine, i actually think i'm hearing the rockers tap on the valves until the lifters pump up with oil completely. I also have the piston slap noise but that you can't miss, its a klacking knocking noise that goes away after it warms up.
If i drive it easy for a few 100 miles the noise goes away completely, then if i run it hard it comes back. I guess gm has some lifter issues.
