Will an LS1 Idle without the LID on? (safely!)
PLMK, thanks!
As for the original post, youll get an SES light Im sure, but just make sure it doesnt suck anything up. Running it for that short of a time shouldnt do any damage.
wasnt there a thread where a guy sucked a red shop rage through the engine? hahaha
change your oil when its hot, it flows quicker, who wants to wait around for cold oil to run out? also if you want to clean your motor really good! drain the oil, fill it back up with diesel and run for 5 min, drain the diesel and change the filter, finally fill it back up with oil of choice.
Which reminds me, when I was young I worked a stint in a radiator shop and across the street was a transmission shop, the owner drove a Dodge dart w/ a slant 6 engine, he swore by running his engine with ATF oil inside, he claimed he got 300k miles out of all of his cars....he did like the gonja too
Only harm would be running it in dusty conditions. I'm sure you wouldn't do that.
Also, if the MAF is still hooked to the connector but not to the TB, it will stall. You'll need a little help with the throttle to keep it alive.
