Call Me Crazy, & Beat me Silly. Im sticking with JPR.
Bear, do you have a written copy of exactly what the warranty is for your engine? I would make sure I had a written warranty and that it clearly spelled who JPR or JD or both etc would take care of any warranty issues that occur. Given the current state with two members having issues it's critical to get a written warranty in case something occurs.
I'm sure every sponsor has been bashed at one time or another. It will take more than one or two unhappy people to make me change my opinion about someone. When my setup is ready, I plan to just drop the car off and pick it up when it is tuned and 100% ready to go. Whatever suggesstions I am presented with (cam, ect.) is what I will go with. They are the expert, not me. I will probably stay in town a day or two to break it in and be there if it needs to go back for a glitch. BTW, if anyone at JPR reads this, please reply to the e-mail I sent last week (I know you are busy) or pm me. Just want to get an update on my order and when it may be ready. I can't call from over here. Will be back in 5 weeks Later!
Originally Posted by JS
IMO it should dyno about 500/475
I figure it should make---->1.2HP per cube.
Originally Posted by Chris ARE 360
Spend the 50 bucks and throw a cutout on there. It'll be worth at least 20 RWHP compared to that Corsa
definately get a cutout. If you get the cutout im going with 503/488, otherwise im going with 495/468
No cutout for me. I done CARE. I had a QTP on the SS and I didnt like it. Not QTP's fault but the wire from the switch fell off the cutout, I see people needing to adjust them everyonce in a while. You cant run them at ETown so forget it. I can do with the extra little powah.
$15K for a big inch motor? No warranty?
Way too risky for me. I know a guy in Vegas that runs a 150 shot and runs 10.8's with cam/converter/headers.
#34
CARTEK Racing
well since the motor was built by Joe, looks like it will dyno about 515RW and run 11.30's... that is before it lets go.
I hope for your sake, Joe can atleast put ONE motor together. My prayers are with you Bear. But we have all warned you, now its done, so we will see what happens.
#35
#36
#37
Originally Posted by I8COBRA
I say 0hp/0tq.
Its gonna blow up on the dyno
Way to inspire someone *******..Joe seem's like a good guy to me..and JD's is a top notch place..Bear I think you are in good hand's man..Good luck..BTW what head's are on this motor,compression and cam specs?
#38
Compression is 10.8 ---->11.0. I am not posiyve. When the gaskets went on and everything got buttoned up I will have a better answer.
Cam is a Comp Non XRE, 242/242 .600 .600 112
I DID NOT GO ALL OUT ON THE CAM. Since my car is heavy I will never set any records. I chose a big *** motor with lots of torque to make up for it. I will drive this thing around town and when I have somewhere to go. I dont use this as my DD. I want streetabilty and power. My car has full interior plus sound system.
#39
Originally Posted by Bear
Heads are JPR LS6 S2.125(basically S2, cleaned up a little after the first bottom end let go.) New Valves, dont know the size, Crane Dual Springs.
Cool man..sound's like a very fun streetable motor I will guess 486 RWHP Have fun with it and go get that sucker dynoed
#40
Suck my wad Mr. Behind the Keyboard Toughguy, I call 'em like I see 'em.
