LS6 Cam Power
i have one in my 5.3 paid 160 shipped for the cam and springs....the ls6 cam loves boost or spray and has a broader powerband than either 2 of the ls1 cams.....
and whats his suspension have to do with the thrread???my cars been bottom 1.6s on stock million mile suspension at full weight....
it has everything to do with it, i said id believe it when i saw the times and i dont believe just the ls6 swap would yield those track times. if hes got a full suspension setup it def is relevant. i usually see pretty good size cam only cars with bolt ons stock suspension going 11.7-11.8. i dont see one as small as the ls6 and 243's alone putting up 11.9.
i dont mind being wrong, im just curious asking questions
and before anyone says thats a b4c, they are identical to z28's.
If the cam was worth it z06 owners wouldnt scrap them. If it were me i would go with a 224 cam amd a set of 243s just my .02 cents..
op Listen to what guys are tellin you, the ls6 cam is a waste! Look into the lpe gt2-3 or the tr cheater v.3 cam. Both will drive like stock and yield 30+ whp gain. Best choice would be to contact geoff at eps, those eps lobes are very easy on springs...
