02 WS6 Knocking Please Help !!!!!
Old Nov 3, 2009 | 06:59 PM
twadd's Avatar
Originally Posted by capt.ld
dam i better check mine like that couse i have a funny sound at 2500 rpm and im thinking a rod also.but mine at cold nocks and warm it does it at 25 and up but not louder just stays the same and dont go away.
LS1 noise sux !!
Old Nov 3, 2009 | 07:09 PM
capt.ld's Avatar
yea it does i just wounder if i can change the rod barrings in the car from the bottom.ill half to drop the oil pan and check them all.god thats going to suck bad.couse im not sure what it is.
Old Nov 3, 2009 | 07:17 PM
twadd's Avatar
Just a guessing game huh? You gonna tackle that soon ?
Old Nov 3, 2009 | 07:18 PM
rdd014camaro's Avatar
That does kinda sound like a spun bearing. with only 25k on the car. that sucks dude. just replaced my engine due to a bad rod bearing.
Old Nov 3, 2009 | 07:21 PM
twadd's Avatar
You just replaced the whole engine ? That cost a pretty penny !
Old Nov 3, 2009 | 07:22 PM
You can buy an in car engine bracket from harbor freight. Basically it grabs the engine and mounts to the shock mounts. Then you can drop the subfram and have everything right there. Getting a crank turned is about 90 bucks. Or you can just buy the crank kit which comes with crank and appropriate main and rod bearings for about 250bucks. just make sure your rod diamater hasnt gotten beat out of roundness
Old Nov 3, 2009 | 07:24 PM
well i found a short block with about 35k on it for cheap. didnt feel like tearing into the engine. even though its not to bad. I just wanted to pull one out and put the other right back in
Old Nov 3, 2009 | 07:27 PM
twadd's Avatar
I dont blame you.
Old Nov 6, 2009 | 05:37 PM
twadd's Avatar
Sold car last night
