Pushing coolant out of overflow at WOT only
car is a h/c ls1
T-stat has nothing to do with it. If it sticks closed you will over heat no matter what your doing. If it sticks open you will over heat in city driving, but it will be fine on the highway.
Blown gasket....possible but not likely. Usually once a hole starts, you will have air getting pushed into the cooling system the whole time, whether at idle or WOT. It will just vary how much with rpm. But you probably wouldn't last much more than 15-20 minutes if a gasket is blown.
