head combustion chamber cc questions
Old Nov 7, 2009 | 01:50 PM
rggbly's Avatar
Default head combustion chamber cc questions
what is the factory combustion chamber size in a 241 head? what compression is a 68cc chamber gonna put me at with stock pistons? thanks
Old Nov 7, 2009 | 02:30 PM
02*C5's Avatar
On an LS1 stock configuration;
W/ 241 heads 10:1
What are you future plans? If I can give you some advice do not buy 241's. Reason I made the same mistake did not listen to any one. The 243s are better heads. It has a lot to do with the runners. The 243s have stock 212CC intake runners and the 241s have 260cc runners. The larger runners are shitty for low to mid range hp, throttle response and performance.
Old Nov 7, 2009 | 03:24 PM
outkast6991's Avatar
241's do not have 260cc runners.
Old Nov 7, 2009 | 03:54 PM
rggbly's Avatar
yea i don't see them having 260cc intake runners. i have a set of 241's right now that are p&p by absolute speed. previous owner put down 416 to the wheels on a mustang dyno with just a 224 cam..that's pretty damn good. anyway. i need to know the cc of the combustion chamber. not the intake runners. also a relative compression with stock pistons and 68cc heads
Old Nov 7, 2009 | 04:19 PM
BaddBird's Avatar
IIRC the 243s have a 210cc intake runner and the 241s have a 200cc runner. The 241s compression is 10:1 The 243s will give you 10.5:1
Old Nov 7, 2009 | 05:52 PM
rggbly's Avatar
thanks. i need to know what the actual size of the combustion chambers are. not just the compression. at wat cc is it making 10.1 and 10.5. i already know what compression you get. just need to know what cc the combustion chambers are. thanks
Old Nov 7, 2009 | 05:59 PM
BaddBird's Avatar
241s are 66.67cc
and the 243s are 64.45cc
Old Nov 7, 2009 | 08:03 PM
02*C5's Avatar
your right wtf was i thinking here is info on complete stock ls heads
https://ls1tech.com/forums/generatio...ead-guide.html
Old Nov 8, 2009 | 12:08 AM
rggbly's Avatar
that's exactly what i needed to know. thanks a lot fellas
