Knocking help
Old Nov 9, 2009 | 12:03 PM
1998Chv37s's Avatar
Default Knocking help
I cranked up my car this morning and sounded unusually loud.. I got on it when driving off and heard a knocking noise. I got back home and noticed the oil was low so i added oil. The knocking is hard to hear at idle but when it gets pass 2500-3000 you being to hear it. Sounds like it is coming from right under the intake. I did let a friend drive my car last night at the drag strip and well he spun through every gear and hit the limiter in every gear (1-3)
Any ideas as to what it can be??
Oil pressure seems to be a tad lower than before but as rpms increase so does oil pressure, the car pulls fine, runs fine, idles fine, just got a knock.
Maybe cam bolts? bearings? main bearings? rods?
Everything in internal is stock besides heads and cam
Old Nov 11, 2009 | 03:02 PM
1998Chv37s's Avatar
Any idea as to what it might be? Its not really a knocking noise more of a ticking noise coming from the front of the engine
Old Nov 11, 2009 | 03:24 PM
mwatson185's Avatar
Pull your oil filter off and cut it open, search for metal shavings. Also check the magnetic drain plug. That will be a good sign of a spun bearing etc...
Your friend couuld have floated the valves bouncing off the rev limiter and done a bit of damage to your valve train from PTV contact. You could have a bent pushrod or valve, or a collapsed lifter.
Old Nov 11, 2009 | 03:28 PM
1998Chv37s's Avatar
if it was the bearing the car wouldnt be running fine would it? Just odd to me. I drove it back home and parked it to get my truck ive driven it maybe 50 miles or so after i noticed it and it was no diff.
Old Nov 11, 2009 | 03:30 PM
1998Chv37s's Avatar
Im leaning towards the lifter by the way it sounds, a buddy of mine came and looked at it at first when i explained to him he said bearing but when he heard it he said that wasnt it. he talked to lorenz a guy he used to work for an tune ls1s around my area and he said cam bolts.
Old Nov 11, 2009 | 05:19 PM
1998Chv37s's Avatar
Lifter maybe? opinions! need HELP
Old Dec 1, 2009 | 08:53 AM
NeXuS's Avatar
Ever Figure it out.. i have a simlar issue.
