can oil affect yoru power out put?
Originally Posted by 2001CamaroGuy
I was told synthtics are not "bad" for posi, but rather is can actually be too slick and cause the clutches to slip. This won't hurt the clutches but just turns your exspensive posi into an open diff. The slip addative is a thickener than helps the clutches engage better.
When I bought my 99 Z28 a lil while back I changed the oil & put Quaker State 10W-30 Full Synthetic oil in it. I would have put Mobil 1 10W-30 full synthetic in but Autozone was out. I have noticed that my oil pressure runs extremely high. My oil pressure runs at 45 psi when idling at 210 degrees & soars past 70 psi when at WOT. It kind of scares me to see it go so high. Would I be better off running 5W-15 full synthetic?
I'm sure that synthetic oil allows for more power. Back in the day I had my 85 & 88 Mustangs I read a article in Mustangs & Fast Fords that had a dyno comparison with 10W-30 multi grade oil & 10W30 full synthetic oil. The synthetic oil was good for 7 RWHP on a Mustang.
