Keep LS1 Block or Get a New Motor
I just found out my number 7 piston has a hole in it and is causing a severe misfire. My car has 104k on it. Basically bone stock. Will the LS1 block be fine to rebuild or should I buy a short or long block and start new?
I would get a good running pull out short-block. Either an LS1 or LQ9. You will find that they are rather proud of the LQ9s. Then just swap all your stuff over. Thats what I did. And you can sell your block and crank and whatever else you dont use.
https://ls1tech.com/forums/racers-lo...ew-engine.html
If there's no damage you'd be fine with a hone to 3.905" and rebuild from there.
You'd need to look at the cost of the strip-down, check, hone, new set of pistons, bearings, pumps, gaskets etc. compared to buying a decent iron block LQ4 and stripping the LS1 of the parts needed to get the LQ4 car-ready.
Checkout www.texas-speed.com we have plenty of short-blocks in stock! If you can pickup a few extra cubes for nearly the same money do it!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
