Ring selection for a little spray?
Old Nov 15, 2009 | 09:27 PM
JRracing's Avatar
Default Ring selection for a little spray?
I am going through my 383 over the winter and setting it up for a 100-250 shot next year. And switching the cam for a nitrious friendly grind.
Should I take the Hasting molly rings out and put a better n2o ring set in the motor?
Any recommendations?
Old Nov 16, 2009 | 09:38 AM
Jon@Texas-Speed's Avatar
If you are going over 150 I would recommend going to a steel/napier ringset. The stainless steel top ring will help deflect some of the heat and will withstand more abuse than a standard plasma-moly ring. What pistons do you have in your combo? Do you know if they are a standard 1.5/1.5/3mm setup? Let us know and we can more than likely get you setup with the right ring for your combo.
Jon
Old Nov 16, 2009 | 08:53 PM
JRracing's Avatar
Jon, thanks for the advice. It has diamond -2cc flat tops in it. 3.905" bore. Could you PM me a price on them. I looked through your site a few times for rings and did not see much. I'll look again.
Old Nov 17, 2009 | 09:36 AM
I PM'd you some info. and pricing! Let me know if we can help!
Jon
Old Nov 17, 2009 | 09:45 AM
PREDATOR-Z's Avatar
Hellfire
Old Nov 17, 2009 | 09:54 AM
ssman00's Avatar
if you could jon pm me the same info and price as i have the same setup and need something to handle some spray
Old Nov 17, 2009 | 07:46 PM
JRracing's Avatar
Originally Posted by PREDATOR-Z
Hellfire
Were can I find these rings? I have heard of them but have not seen a vendor that sells them. Are they pricey?
Old Nov 17, 2009 | 07:49 PM
JRracing's Avatar
Jon
Thanks Jon. The diamond rings are a little on the expensive side. I will do a little research for a while and get back to you if I go with the diamond rings.
Old Nov 17, 2009 | 07:51 PM
JRracing's Avatar
What about these? They do not say anything about n2o usage.
http://www.sdparts.com/catalog/lsgen...stonRings.aspx
By Brett Foote | 2026-06-04 05:00:17
