knock sensor help!
Old Nov 16, 2009 | 07:15 PM
lt1formula275's Avatar
Question knock sensor help!
well im looking at a 1999 ws6 trans am auto the check engine light is on in it and the guy took it to autozone and the code is bo327 says the knock sensor is picking up knock in number 1 cylinder. my question is how do u tell if its false knock? the car is bone stock has 122000miles had transmission rebuilt at around 100k
Old Nov 16, 2009 | 07:43 PM
1quickirocz's Avatar
p0327 is for the front knock sensor which should be bank 1(left side of the engine). The pcm cant differ between cyl 1,2 ect. as far as knock. It can only tell bank 1 or 2. Its probobly either the sensor or the jumper harness. That is ofcourse if you dont actually hear an engine mechanical noise. As far as false knock i would have to say no.
Old Nov 16, 2009 | 08:03 PM
ok if it was either of those 2 u said are they hard to fix and if it does have a major problem can u hear it knocking
Old Nov 16, 2009 | 08:14 PM
if its an engine mechanical issue causing it then yes you should be able to hear it. lS1s make alot of noise anyways but the PCM is looking for something out of the normal to set that code. As far as being hard to fix thats kind of depending on your ability. Both sensors are under the intake manifold so obviously that needs to come off. But thats about it. not too bad. something else to think about is if it has some type of pulley bearing noise or even power steering pump noise. I have seen both of those cause the front knock sensor to go crazy.
Old Nov 16, 2009 | 09:32 PM
i just dont want to buy it and it have a major mechnical issue im only 17 my dad works on our cars a lot he has fixed my lt1 a lot but he hates working on them cause there so compacted in the engine bay just a sensor under the manifold he wouldnt mind doing but like if there was a major issue he wont want to spend time fixing it
Old Nov 17, 2009 | 03:40 PM
i think you would know for sure if there was an engine mechanical issue causing the sensor to go crazy. you would hear it. something like a rod or main bearing or a lifter. stuff like that and you would know it. I say go for the sensor and make sure you check the jumper harness to the sensor.
