ls1 balancer repair sleeve? source?
Old Nov 17, 2009 | 10:33 AM
73 nova guy's Avatar
Default ls1 balancer repair sleeve? source?
i am doing a ls swap in my nova and the balancer has a grove in witch is making the cover leak..
can some one refer me to a source to purchase a repair sleeve or am i still in sbc land and need to buy a new balancer?
Old Nov 17, 2009 | 11:19 AM
NemeSS's Avatar
NEW,UDP, summit,or even a pro products
Old Nov 17, 2009 | 11:40 AM
5.3LJimmy's Avatar
It is important to install a new seal and use the balancer to center the front cover before completely tightening the bolts. This will align the cover and prevent the seal from leaking. I do not think anyone makes a repair sleeve for the LS1 pulley, so if the above procedure doesn't work get a new underdrive pulley.
Old Nov 17, 2009 | 11:56 AM
yes all i have found id gen I sbc ones. looks like i may need to get a new pulley
Old Nov 17, 2009 | 04:51 PM
O2Form's Avatar
Try a new seal it may contact in a different area or don't push the seal in quite as far. Its not critical you only need to move it 20 thous or so.
Old Nov 17, 2009 | 05:39 PM
its grooved pretty good.. also i don't want it to chuck the belt of then if its not properly aligned
Old Nov 17, 2009 | 05:53 PM
O2Form's Avatar
I didn't mean to let the balancer out any, just don't push the seal in the cover as far or just try a new seal 1st..it may be ok. The old seal was hard and worn. A new seal will probably seal fine.
On a side note i'm near Stroudsburg.
Old Nov 17, 2009 | 09:18 PM
oh were at?
Old Nov 18, 2009 | 10:04 AM
O2Form's Avatar
blue mt ski area
Old Nov 18, 2009 | 03:39 PM
blue mt ski area
oh ok.. there isn't many guys or gals in this area doing ls any thing. i got one guy in marshalls creak doing a ls1 6 speed swap in a rx7 and my 6.0l turbo nova that's about it
