View Poll Results: Best PCV system?
None
4
25.00%
LS6 valley cover
1
6.25%
LS6 valley cover + catch can
5
31.25%
LS1 system + catch can
1
6.25%
Other: Please specify
5
31.25%
Voters: 16. You may not vote on this poll
PCV poll
Old Nov 17, 2009 | 12:43 PM
k5383's Avatar
Default PCV poll
Truly what works best and why?
I have read a whole **** load of stuff. and everybody has their own opinion on what works best.
From what I know (SBC Gen1) a PCV system is a must, because it vents out all the gases and helps seals not blow out.
I was under the impression that stock ls1 systems suck, there is not baffle for the PCV valve, and it sucks oil at high RPMS. The best cure for this is a Ls6 valley cover, and a catch can.
Any other opinions?
Old Nov 17, 2009 | 02:15 PM
jetblast's Avatar
http://www.enginebuildermag.com/Arti..._be_right.aspx
personally i rather have a vacuum pump to evacuate to atmosphere all the crap the buids up inside. the car is just a street car though.
Old Nov 17, 2009 | 02:25 PM
99Bluz28's Avatar
Just add a Catch Can to your current system.
If you still have the stock pcv system on your 99, just adding a catch can to the system will help A lot, especially if you mount it away from direct engine heat. That's what I did with my car.
Old Nov 17, 2009 | 03:44 PM
99SSAGUI's Avatar
You don't want to completely remove your PCV system on a street car. if you have the time I will go with the LS6 Valle cover, but a catch can should do the job.
Old Nov 17, 2009 | 05:28 PM
vettenuts's Avatar
04 and up valley cover, places the PCV restriction under the cover and cleans up the engine compartment. I use this with a catch can.
Old Nov 17, 2009 | 06:02 PM
slammin86's Avatar
Dual catch can and one way check valve vented to atmosphere.
Old Nov 18, 2009 | 10:51 PM
dudeman's Avatar
http://www.summitracing.com/parts/SUM-120108/
i have this and it works fine.
Old Nov 18, 2009 | 10:57 PM
elias_799's Avatar
breather on each valve cover. that's it. the inside of my intake is spotless. but you do have to stay on top of your oil changes, because oil will get contaminated more easily. i do synthetic oil every 3000miles.
Old Nov 19, 2009 | 08:09 PM
printmanjackson's Avatar
Any other opinions?
I agree
