Rebuild, run as-is, or inspect to decide?
I just ran a carfax and discovered that the vehicle had 130k on it when it was wrecked.
I've never pulled a shortblock apart before without doing a full rebuild, but I really don't want to do that here because it'll blow my budget out of the water. If I pull the shortblock apart and find that all of my crank surfaces are within spec, can I just throw new crank & rod bearings in it, put it back together and call it a day, or should I still get the journals honed and use the proper oversized bearings?
Ok to replace pistons & rings without doing an overbore?
theres a write up on this site on how to do using oversized valves and coarse sanding discs
