engine stand help asap!!!
Old Dec 11, 2003 | 02:10 PM
98sspullin'em's Avatar
Default engine stand help asap!!!
i need to know what bolts you used when you put the block on the engine stand?? the one i have, you put the bolts in the back of the stand and screw it into the block?? they only have to be about 3-5 inches long,,, what is the size of them?? and is there any that came off the engine that i can use?? everything is off of it but the cam!! thanks
Old Dec 11, 2003 | 02:38 PM
UGotBeaT's Avatar
You can use some bell housing bolts but they're not long enough so I just went to autozone and bought 3 that were like an inch longer.
Old Dec 11, 2003 | 02:39 PM
Kens_02SS's Avatar
Call this guy at Panadigm Engineering ( Charlie) they build engine stands: 661-296-4147
Old Dec 11, 2003 | 02:51 PM
LS1x2's Avatar
Formerly 4mulaJoe
ACE Hardware stores have tons of bolts. I beleive they are M10x1.5. You can measure the length you need.
Old Dec 11, 2003 | 03:12 PM
robertbartsch's Avatar
...home depo sells bolts too...
Old Dec 11, 2003 | 07:17 PM
Q's Avatar
Q
yup home depot 10x 1.5 (70mm) on ac delco stand.
