Got a new cam...Need help choosing springs/retainers
I decided to go with a very mild cam. And I just got a great deal on the SLP 216/220 .524"/.530". SLP and all their distributors say that new valve springs and retainers along with tuning are required. Which ones do you guys think I should go for? I was considering Comp 918s or Manelys with ti retainers. I dont want to go too extreme like double springs unless I really need it. Should I be concerned with a spring that has too strong of a spring rate? Would that damage my cam, bend a rod or a valve, or break a rocker? Also, do I need to be concerned about coil bind?
Thanks for any suggestions...
SN95 Director
i dont know how aggressive the ramps are but some ls6 springs would fit the bill also, 02+ springs that is. there excellent for longevity. the manley springs or 918's will work also seeing as your cam is very mild lift and duration. i bought the manley kit for my cam, 178 w/ tit retainers from SDPC2k, there a sponsor.
I'd go with the 918's and stock retainers, that combo is hard to beat for almost any cam. I even ran 918's with stock retainers on my TSP231/237 up to 6,800rpm for about 2,000 miles before switching to the new patirot duals.
Thanks, guys. I just called up SDPC (website not working) and ordered the Manley springs and Ti retainers. Cant wait to get all this installed. Also, do I need to worry about intalled height? If so, how do I measure and adjust for that?
Good pick going with the manley springs and retainers, I just had some bad luck with 02 ls6 valve springs on my car only lasted 400 miles.And my cam is just like yours, I purchased the same springs and retainers as you and will have to wait till spring to install.
I have to agree the Manleys with the Tit Rets for 178.00 is very hard to pass up, I am down to them or the new patroit duals for my tr230.
as for the Keepers they have them for 19.00 where you got your springs from
Pete
Pete
