When doing a compression test.......
Old Dec 12, 2003 | 02:48 PM
BLASTER's Avatar
Question When doing a compression test.......
How do you disconnect teh fuel system? I just pulled the throttle cable off the TB. I don't want to be dumping fuel into the system as I crank. Thanks
Old Dec 12, 2003 | 06:41 PM
CAT3's Avatar
Restricted User
remove the fuse, right on the left fender well! The cable wont stop the fuel pump from priming the system.
Old Dec 12, 2003 | 09:15 PM
BergerMan's Avatar
I would do more than just disable the fuel system:
#1 Unplug each bank of coil packs from the main harness. Its the large connector in the center.
#2 Unplug each fuel injector.
#3 Hold the throttle open while cranking it over 5 or 6 times or until the needle stops climbing.
You should have 190-210psi on each cylinder
Old Dec 12, 2003 | 09:21 PM
CAT3's Avatar
Restricted User
Yeah, forgot to finish huh? Its always the little things. I do recommend making sure you crank each cyl an equal time, or crank. Helps ensure your comparing apples to apples.
