help needed
Old Nov 26, 2009 | 10:42 PM
sloganish's Avatar
Default help needed
My setup is going to be the following; stock bottom end ls1, FAST 92mm intake, longtubes, patriot stage 2 ls6 heads, FAST 36lb injectors, lpe fuel pump, ported ls2 throttle body, I want a giant cam, something with great peak horsepower, as well as a strong running curve, I don't care a bit about drivability, this will be in an m6 c5 vette with a 3.73 gear. How big can I go? I will also be spraying 100-150 wet at the track only, so a nitrous friendly cam isn't completley necessary
Old Nov 27, 2009 | 09:46 AM
johnster's Avatar
trex is about as big as you can go and thats if the heads are 66cc. nless you wont to flycut
Old Nov 27, 2009 | 09:54 AM
DarkJuggalo's Avatar
my choice is and will always be polluter from tick
Old Nov 27, 2009 | 08:00 PM
cky945's Avatar
edit.......
Old Nov 28, 2009 | 01:12 PM
sloganish's Avatar
bumpp
