Is this a good combo for 400rwhp?
vehicle 2006 Silvy 4x4 Z-71, 4L65E built, Yank 3000, 4.10 Gears, 4500lbs
5.3 iron block, 3.905 bore, 9.235 deck, arp main studs, db cam bearings and
Coated rod and main Bearings
4.00 stroke scat crank, Compstar 6.125 rods, Manley Fully coated Pistons 11.47:1 comp with steel rings, -010 with .045 MLS
Dart 205cc Hand Ported heads, by me, 300cfm at .550 lift 240ex at .550 2.05 1.6 valves, pac 918's, ti ret ect
Custom cam 226-230 at 50 .596in .580ex 112lsa 108ilc, ls7 lifters
Comp SS 1.82 rockers with 3-8 .065 wall p-rods
Ported factory truck intake, literally cut in half, ported then epoxied back together with ported TB, stock injectors,fuel pump, and lines
Long Tube SS 1-7/8 headers, NCY Magnaflow dual CB
Custom Tune by Wongs Performance
If $ permits i want to find a Fast 90M for sale for around 750 with rails,injectors, id buy it, anyways in your best guess what do you guys think this will do?, Thanks a bunch in advance, Derek
