Poll on Big Bores 382-388 & leaking issues
Mikey, thank for the info on the ARE sleeved blocks.
Thanks
5 without issues over 15,000 miles
5 with cooling issues
Note: Steve has 5 Darton Wet's that havent reached 15,000 miles that have zero issues.
I have no problems whatsoever, other than clutch
.But I cant choose one of the above, because I dont have 15k miles. I only drive the car for pleasure when its not raining. So it has to be dry here adn I have to have a couple spare hours on my hands. HA! No wonder Ive driven it so little.
I have shared loads of crappy experiences... they just arent with MTI or with my LA Sleeved 387.
chris
Thanks!
Stats:
Poll-10 votes-5 without issues over 15,000 miles & 5 with cooling issues
Notes:
Visceral - has LA Dry w/no issues todate.
50 percent problem rate overall
Out of those voting even the ARE re-sleeves which have been held in high regard for being problem free are show about the same rate of problems as the other set ups.
The Block is ARE, and is O-ringed with copper gaskets. I'm told that the leaking is from the O ring/copper gaskets. I reduced it alot by crushing up and putting the GM pellets in the radiator.
Nate
