New Cam Specs
Old Dec 12, 2009 | 08:42 PM
highway21's Avatar
Originally Posted by CUR 4 VNM
cant wait to see this thing running around with a cam. are you going to quite that exhaust down though?
nope keeping the 3" dual exhaust setup.. have you herd it in person the way it is now? can only imagine what its going to sound like with the cam.. crazy! going to intimidate people more then anything, whats done to your ws6?
Old Dec 14, 2009 | 12:47 AM
Kingc8r's Avatar
He has a Firehawk, His girl has a WS6 though....cops will love those TDs.....
Old Dec 14, 2009 | 02:01 AM
Nitroused383's Avatar
I run unported 243 heads that I had milled and I did a 5 angle valve job to. Make sure the valve job is hand blended into the throat, just make sure its a smooth transition from the seat to the aluminum. I also had my heads milled .020" which put them right at 62cc which = 11:1 compression with GM .051" MLS gaskets. You will have to flycut with that cam if you mill your heads.
If the valve job is done right and is not just a generic 5 angle job you will see some very nice gains from that alone. 450rwhp should be about right with a fast intake, underdrive, good headers, cutout and a 6 speed. Hope you realize you will be losing power by advancing the timing. On most 243 head setups peak power is around 22-26 degress of timing. It's not about the max timing its about the most efficient combustion, and every setup is different.
Old Dec 14, 2009 | 04:11 AM
mark21742's Avatar
when I ported my heads the exhaust volume almost doubled with my 3" true duals over unported....you'll love it
I'm hoping to test fire and start tuning my 04 goat today when I get off work, milled .037" off the heads and dropped in a Trickflow 238/242 ..595/.595 112lsa.......i can't wait to hear what this thing sounds like with 15° of overlap
