LS1 Essential Upgrades?
Old Dec 20, 2009 | 01:23 PM
hammertime's Avatar
Originally Posted by Klubba
Thank you for a very good post, after doing some reading on rod bolts and spinning bearings, I've decided its safest not to touch them at all.
You mean i should keep the stock pump? (from what I've read the ones 2001- shouldn't fail) or swap it for a melling with stock pressure/volume?
i think id sleep better with a high press melling pump thou ^.^
For insurance purposes, I agree with replacing the pump. I can't say your application warrants a high volume or high pressure pump, but if it makes you feel better, I also don't see it hurting much.
On anOther note - this is the thread I was looking for, more good reading here.
Maximum Overlap on F-Body Stock Manifolds
Lot's of tech contained within on how and why particular valve events are chosen. Post # 42 contains the final results - a 210/222 112 110 .595/.581 cam ground with XFI/XE-R lobes and 344 HP and 339 ft-lbs on a Mustang Dyno. That's gotta be 355-365rwhp on a dynojet and 350-360 ft-lbs. You also have room to improve with better flowing heads and intake, without compromising reliabilty or drivability.
Hopefully that helps you out some - best of luck!
Old Apr 26, 2012 | 08:37 PM
David Kaufer's Avatar
So what is the most common upgrade to the ls1?
Old Feb 8, 2014 | 12:55 PM
S_Sprouse's Avatar
lid ...
Old Feb 9, 2014 | 02:15 AM
RAGaines3's Avatar
oil pump, front and rear main seals. check the rotating assembly while your in there. pcv is usually gone. headers are an excellent 1st bolt on and if ya got the cash h/c and valvetrain upgrade. LS1's are great but like anything else they only take so much abuse. Have fun with it, ought to be a hell of a lot of fun in a lightweight iroc.
