ls1 heads
Old Dec 19, 2009 | 12:01 PM
jgh64pkup's Avatar
Default ls1 heads
what are the biggest valves you can put in an ls1
Old Dec 20, 2009 | 02:47 PM
jgh64pkup's Avatar
anybody?
Old Dec 21, 2009 | 09:31 AM
Jon@Texas-Speed's Avatar
On the stock seat we have put a 2.04" valve before but more commonly put a 2.02". With aftermarket seats I've seen some heads with 2.100"+ valve sizes.
Jon
Old Dec 21, 2009 | 12:09 PM
jgh64pkup's Avatar
so no way l92 heads will fit
Old Dec 21, 2009 | 02:55 PM
On a LS1/LS6 block, L92 heads will not fit. L92 heads will require a 4"+bore size.
Jon
Old Dec 21, 2009 | 05:14 PM
jgh64pkup's Avatar
alright what would be a good hp head a stock one from gm
what about the 243 ls6 heads?
Old Dec 21, 2009 | 08:27 PM
Paul57's Avatar
I believe the 243s are the best heads you will find (not counting the L92s).
The 317s flow similar to the 243s but have bigger combustion chambers.
So, it would depend somewhat on the compression ratio you would like to achieve.
Old Dec 21, 2009 | 11:00 PM
jgh64pkup's Avatar
i want about 9 to 1 on an iron ls1
so i can put a turbo on it
what turbo do you suggest
right now i have a 68mm
