Will I need to drill the throttle body with tuning and cam?
usually that isnt neccessary. the tuning should make it run much better. just wait and see how it does after the tuning
i had to drill mine 1/4 to get mine to idle... i probably went one size to big though. I have my idle at 975 also
best thing you can do is monitor your IAC's in park when the car is fully warm. They should be in the 20-40 range for best results
I installed a tr224 114 cam this weekend, and I will be going in for dyno tuning on Friday. Right now the car dies sometimes when I come to a stop or when I put it in gear at an idle. Also right now I have the stock torque converter back in my car, but that will change in about 2-3 weeks. If I am getting dyno tuning do you think I will need to drill the throttle blade?
