How do you build a custom head/cam combo? Conflicting advice...
It's my daily driver in the summers. I don't want a high idle, and definitely don't want the crappy gas mileage that comes with that.
When I get my heads back from being worked/flowed we'll see what my chambers CC at. I'm curious how high my compression is... perhaps that's what's exacerbating the harshness of the stumble.
You shouldn't be getting bad gas mileage. My cam has way more overlap than your cam and I have seen 28 mpg in my 3500lb 6 speed camaro. My car idles at 900 rpm too. I get an average of 20 in town and 25 on the highway. Its all in the tune. Overlap produces natural egr in an engine to take up cylinder volume at lower rpms. This can actually help mileage with a proper setup. GM uses egr to their advantage on stock engines for fuel economy.
The car dropped a valve earlier in the year. I didn't take the heads off then and the dyno numbers and track numbers came after I fixed it. I'd still like to take everything apart for peace of mind, and I have a hook-up with Opel Engineering. Also, as part of my driveability quest, I'd like to have less valvetrain chatter. My lifters have 100k on them and are original '98 spec. I'm not sure if the bent pushrod (from the dropped valve) did any damage to that lifter but I'd like to change them all anyway. Plus doing all of this has a side benefit of not worrying about the lifters falling when I swap the cam.
I'm expecting to lose ~20whp by going to a cam that has stock like idle. I might gain 5-10whp from the valve job and headwork but I'll still be down at least 10whp. Adding the stickier tires should put me right where I want to be, if not a little faster.
It's not really about dollar-to-horsepower for me. The car is nearly perfect and it's about getting it to be that last 5% where I want it to be.
Your current cam at 225/225 112 has only 1 degree of overlap at .050" lift, so you'll have to go less than that to get an improvement in mileage and manners. An agressive profile will have more duration at higher lifts, at the expense of some additional NVH over a milder profile. With your exhaust, you can probably go to a reverse split to reduce overlap. For example, a 224/222 XFI/XE-R cam on a 114 LSA has 4-5 degress less overlap and still run 149degrees duration at .200" lift.
Best of luck!
PatG recommended a milder road-race type lobe. If it weren't for wanting milder lobes, I'd probably just throw an LPE GT2-3 in the car and be done with it. People have made 360whp with it on stock heads and if I can make 390-400whp with my heads all freshened and optimized, I'd be stoked. I think I remember Pat saying he could go more aggressive on the overlap and lift than the GT2-3 and still have it behave like one at idle. That'd be ideal. Aside from that, I'll probably heavily wrap the longtubes and see if I can muffle the valvetrain noise some more.
I know it sounds like I'm defeating the purpose of having a big V8, but trust me, the difference between the limp-gutless-no-torque Rotary that was in the car is night and day, even on a bone stock LS1.
Thanks for the advice!
That's part of the reason I'm taking the heads off.
