mystery engine?
Old Jan 3, 2010 | 06:08 PM
lifeisgood's Avatar
Default mystery engine?
So i went to install arp rod bolts for my engine thats going into the lt1 car.
When i took the original rod bolts out and the cap off the bolts wouldnt come out. it took a ratchet to get them out like they were threaded.
after getting them out, i noticed a dowel that was in the cap. it looks like the ones that go on the end of a a rod to line up the cap?
i havent seen them on any other ls1 engines? and idk why they are in there, a couple came out and stay on the bolt?
can any one shed any light on this?
the engine came out of a corvette. it has 853 heads.
Old Jan 3, 2010 | 09:58 PM
5.3LJimmy's Avatar
They are more commonly referred to as rod bolt ferrules on this site. IIRC they were only used on the late 2000 and up engines. You need to pull all of them out of the caps before installing the ARP's. If you search for ferrule you should see plenty of threads on this subject.
Old Jan 3, 2010 | 10:40 PM
01ssreda4's Avatar
I have seen them on an 00 and 01 LS1 and on an 04 LQ4 engine. Most stayed in the cap when removing the rod bolts so I left them when installing ARPs.
Old Jan 3, 2010 | 11:23 PM
Armageddon's Avatar
...with cheese.
I recall one of my old motors still having them left in and it not giving me any trouble.
Old Jan 4, 2010 | 11:46 AM
lifeisgood's Avatar
well if they would have stayed in the caps i wouldnt be that upset. but some of them came out with the bolts. should i just remove them?
Old Jan 4, 2010 | 11:55 AM
outlawnova's Avatar
i had the same thing on the l33 rods
Old Jan 4, 2010 | 12:19 PM
5.3LJimmy's Avatar
When using the ARP bolts it is mandatory that you pull all the ferrules out of the caps. Not doing so will likely result in distortion of the rod cap and bearing failure.
Old Jan 4, 2010 | 02:26 PM
LSxPwrDZ's Avatar
My 04 LQ4 had these also. I installed ARP bolts but you must take the ferrules out cause the ARP has a beveled edge next to the head of the bolt that centers itself on the rod cap and doesnt have the room for these ferrules... I couldn't get my ARP's in without taking these out so it only made sense to me to take them out.
I just took one of the old rod bolts and tapped the others out lightly with a mallet.
Old Jan 5, 2010 | 12:03 PM
lifeisgood's Avatar
thanks guys...will be getting this baby together
