Best 15 degree head on the market??
Studderin, the class is a spin off from another 275 drag radial class that has gotten very expensive to compete in. The fastest cars are running 5.0's to 5.20's. This one was made for the working man,lol. Here is a run down on the rules as they are right now.
275 Real Street
Body & Glass
- Must have working headlights and tail lights
- Stock appearing interior, single seat, carpet, door panels, factory "type" dash
- Lexan permitted (tech will have descretion to not allow "yellowed" or poorly mounted lexan on race day)
- Windows must be operational
- No wheelie bars
Suspension
-stock type suspension factory frame rail
-ladder bar with factory frame rail add 50 lbs
-Coil overs and anti roll okay
Tires
-Maximum rear tire size allowed is 275/60-15 designation
-Tire must be used as intended from manufacturer. No alterations permitted.
Power Adders
-Single type power adder only
Exhaust
-Must have mufflers
Weights-
Small block N/A – 2750 lbs
Small block nitrous .082 jet max– 3150 lbs
Small block turbo 76 mm T4 & D1 or = supercharger - 3300
Big block N/A – 3050 lbs
Big block nitrous .065 jet max – 3450 lbs
Cylinder Head/Induction-
Single stage plate only no multi stages # 4 nitrous line
4150 carb only
23* Chevy - 20* Ford - 18* Mopar - *15 LS
Conventional Iron BB heads only
SB Limited to 427 cu in
BB limited to stock deck height 525 cu in
Buick, Pontiac and Oldsmobile engine combinations run at small block weight
Electronics-
Ignition boxes limited to standard type ignition controls (No Slew or Traction or Boost Controllers)
Digiset or time delay for nitrous control only
EFI okay
We will make an adjustment with weight, tire, jet restriction etc in the future.
275 Real Street
Body & Glass
- No wheelie bars
Suspension
Tires
Power Adders
Exhaust
-Must have mufflers
Weights-
4150 carb only
Electronics-
EFI okay
good lord. that would be very interesting.
