What size injectors
Old Jan 5, 2010 | 01:18 PM
gobigorgohome's Avatar
Default What size injectors
1999 LS-1 out of Camaro: Polished Crank, 11.25:1ish compression, small chamber heads, 550 lift Cam, Howell harness and computer, nothin special tune, turbo 400 tranny
this motor is in my rock crawling/ desert racing buggy
would i see any difference in more that stock injectors??
newbie to the lsx tuning
Old Jan 5, 2010 | 06:13 PM
01ssreda4's Avatar
stock injectors are only good for about stock levels IMO. You should try an SVO red top 30 pounder. About 36 lbs at our pressure.
Old Jan 5, 2010 | 06:28 PM
02*C5's Avatar
Stock Injectors are for years 1999-2000: 26.4 lb/hr.
What you have to see is what your mods are and what duty cycle are your injectors going ot be running. You want to make sure that you never pick an injector that is going to be running more than 80% of its duty cycle. That's about it for injectors.
You never want an injector to stay wide open (Static) or at 100% of duty cycle while your engine is running. Meaning the injector has lost the ability to manage fuel and it is dumping fuel into the cylinder.
Also remember that when choosing an injector you are choosing an injector for fwhp not rwhp.
Hope that helps.
Old Jan 5, 2010 | 06:36 PM
ae13291's Avatar
stick with either the ford red tops, or a EV6 style ford motorsport injector that is also 30lb just looks prettier since its the EV6 style injector
Old Jan 5, 2010 | 06:42 PM
ZL1Killa's Avatar
make sure you have a new fuel pump, and grab some 36# injectors.
you may not need the fuel pump, however, it will ensure you are flowing enough to keep up with the injectors & hold your fuel pressure
Old Jan 5, 2010 | 09:09 PM
thanks for the help, where can i find the ford 30lbers
part number?
and of course i need to re-tune for the injectors if they are more than a couple lb difference?
wil ls2 injectors fit on ls1, i believe they are 30lbs or more
Old Jan 5, 2010 | 09:33 PM
02*C5's Avatar
part number?
http://cgi.ebay.com/ebaymotors/SVO-F...Q5fAccessories
That should take care of it.
Old Jan 6, 2010 | 03:25 PM
will ls2 injectors fit on ls1
Old Jan 6, 2010 | 05:00 PM
Johnnystock's Avatar
No but you can get an adaptor kit...
OP, youd be good with stock 98 injectors(28lbs) since I am with 400+rwhp...
Old Jan 6, 2010 | 05:49 PM
01ssreda4's Avatar
Just bc it runs on them doesnt mean its the right way to go
Old Jan 6, 2010 | 10:55 PM
I know but my tuner said there was still room to grow on em...plus the OP has a very tiny cam/LS6 compared to my bigger cam/ported FAST combo.
Old Jan 6, 2010 | 11:03 PM
ae13291's Avatar
pay 100 bucks and just get some ford 30lb red tops. look on ebay.
Old Jan 7, 2010 | 05:51 AM
ZL1Killa's Avatar
do not get 28# injectors, I wouldn't get 30# injectors even.... just a waste of money IMO. At least go big enough so that if you do further mods (go ahead...say you won't...i would bet you will end up changing something)
grab some 36# injectors FLOW MATCHED & a 255 racetronix kit w/wiring. You cannot go wrong this way.
Old Jan 7, 2010 | 10:30 AM
01ssreda4's Avatar
^^^red top 30s flow 36 at our pressure
Old Jan 10, 2010 | 12:55 PM
like this http://cgi.ebay.com/ebaymotors/musta...Q5fAccessories
or does it need to be a specific year
Old Jan 10, 2010 | 02:19 PM
01ssreda4's Avatar
^^^nope, thats the ones.
Old Jan 10, 2010 | 03:15 PM
tom falco's Avatar
A 30 lb injector will support app 460 HP at 80%
Old Jan 11, 2010 | 01:03 AM
mikemunoz's Avatar
So how bad is it that my injectors duty cycle is hitting 116%. My tunnuer freak out when he saw that. He said bigger inj would fix that. What u guys thinkabout that.my mods are in my signature plus I plan on using 100 shot nitrous. And also my intake is only getting 85%. He said it should be at 100% to get a LS6 intake that its better than the bbk intake I got on. Guys help me out
Old Jan 11, 2010 | 10:26 AM
DSkyles's Avatar
Buy bigger injectors. If you can find 8 injectors for a supercharged 3.8L motor from a GTP or a Regal GS they will flow 42 lbs. on the LS1 fuel pressure. I found a set of 8 new ones on ebay for 150.
Old Jan 11, 2010 | 01:02 PM
ae13291's Avatar
wowowowowow they sold for 64 bucks not a bad price
