SLP 402 Issues
Old Jan 6, 2010 | 08:21 PM
HTX's Avatar
HTX
sounds like u got ripped.
i thats not the case
Old Jan 8, 2010 | 10:24 AM
kahunaking's Avatar
I noticed Today as well on the Drivers side head it is stamped SLP 2# 1520 along with the AFR 1630 part number
Old Jan 8, 2010 | 10:35 AM
WKMCD's Avatar
That is the AFR 225 part number - FWIW
Old Jan 8, 2010 | 11:41 AM
kahunaking's Avatar
I checked on afrs to see that it's a Big bore head as well are there any ways to put a big bore head onto a 5.7?
Old Jan 8, 2010 | 11:56 AM
02*C5's Avatar
If you ever get around to dropping the oil pan and finding out whether its a 6.0L or not if its not then you have a case under "False Pretense," and you need to get your money back.
Old Jan 8, 2010 | 01:49 PM
ViaBellator's Avatar
I noticed you asked this twice, the answer is yes. You can't put L92/LS3/LS7 heads on a smaller bore because the valves will hit the cylinder walls, but those heads would probably bolt on with no clearance issues even on a smaller bore.
