cam for gas milage?
Old Jan 7, 2010 | 01:20 AM
Blackmagik's Avatar
Default cam for gas milage?
Is there such a thing or has anyone even tried to make/research enough to make one.
I have a ls1 block, wiesco pistons and rings, scat H rods, stock crank. I have a BRE cam installed with PAC springs and the correct pushrods. I'm tired of trying to find someone that knows what they are doing with tuning, and I've had to pull this motor for misc. reasons 4 times....tired of messing with it and it gets shitty gas mileage 11 mpg average. I need to replace my lifters soon, so I'm going to replace this cam that's destroying my motors and put something mild in there(might even go with stocker). I plan on spraying it when I race (not very often at all). It's also a DD. Thanks for your time and attention.
Old Jan 7, 2010 | 02:55 AM
itsslow98's Avatar
what is in there now?
Old Jan 7, 2010 | 04:27 AM
mark21742's Avatar
If you really want to go back to stock, I still have the stock cam out of my 04 GTO I'll give you.depnding on your location can meet or should beable to ship it for around $20
Old Jan 7, 2010 | 05:35 AM
DSkyles's Avatar
I'd at the very least put the ls6 cam in it...
Old Jan 7, 2010 | 07:23 AM
Blackmagik's Avatar
The main reason i was thinking about stock was for the tuning, I can go back with a stock tune and decent gas mileage with a stock cam, I've had a ls6 hot cam, and loved it. Depending on if I can get a decent tune, I might go back with another one of those. I get misfires constantly and it dies atleast once for every 3-4 redlights I pull up to.
Thanks for taking the time to read and respond guys.
Old Jan 7, 2010 | 07:30 AM
Blackmagik's Avatar
It's a BRE cam, The owner doesn't want the specs to be know, yadda yadda yadda, but I'd say high120's 618ish lift and 114+5 lsa. But that's just a "educated guess" because I have no cam card (he keeps those)
Old Jan 7, 2010 | 07:36 AM
ringram's Avatar
It probably just needs a proper tune. O2 sensors and maf wont like some cams.
Just get it tuned right and all will be well. Unless the valvetrain is not right which might explain why you mention stuff busting..
Old Jan 7, 2010 | 03:07 PM
yellowjacketfever's Avatar
plus 1 on what ringram said. when the shop did my engine they did a little test drive and dyno before the tune and still on the stock tune. the car would shutter until finally it would go, and die at just about every stop. it took them 21 pulls on the dyno because of a bad factory maf. i have had this current settup for almost 2 yrs and not once has it had to be retuned. i have it checked every 3 months by the same people and we do a drive test. it does sound like you need to get a better tune. if you mind me asking who did your tune and what are they useing. ther are several useing the piggyback system on the lsx's in the okc area. but my shop uses the hptunners and burnes the pcm with the tune. u get so much more out of a tune. he has also taken some of the other cars done by the other person or persons and has gotten them anywhere form 30 to 45 more rwhp. a good tune is more than likely what u need ... good luck!!!
Old Jan 7, 2010 | 09:34 PM
Paul57's Avatar
Theoretically, whichever cam builds the most torque in your driving RPM should give you the best MPGs...with everything else being the same/equal. Here are some to consider, also... http://www.vincihiperformance.com/CA...%20LS1%202.htm
Old Jan 7, 2010 | 10:24 PM
smokinponcho73's Avatar
I would say you need a tune big time. In my 408 with the Magic stick 4 I get 24 on the highway and about 16 around town. Waking the town and allerting the police I get about 12-13 mpg.
Old Jan 8, 2010 | 01:33 AM
mark21742's Avatar
It does sound like you have tuning issues going on. Mine is self tuned with Hptuners, I'm running a 238/242 .595/.595 112lsa idling at 995 rpms and it will stall about once a week when on the brakes and turning the steering wheel... With alittle more airflow/throttle cracker tuning I should have it idling lower and no stalling... I'm a novice tuner and by nomeans a pro and pulling 20 mpg highway/ 15 mpg city lol and under 2 mpg wot
Old Jan 8, 2010 | 03:45 AM
Blackmagik's Avatar
Thank you all for your time and advise, I will seek out a well known tuner that's local and knows my situation. You all answered my questions and pointed me in the direction that I was seeking. Thanks again all
Old Jan 8, 2010 | 06:12 AM
Nitroused383's Avatar
I have the BRE 224 cam in my car and I have gotten 28 mpg highway. My car does not die or misfire at all, but I have spent hours upon hours tuning my car with a wideband. Is it his big duke cam or the 224? Either way they are not beginner cams as they have a lot of overlap.
Old Jan 8, 2010 | 08:10 AM
Blackmagik's Avatar
It's the Duke. I've had cammed cars before and the guy that has been tuning my car says that he knows what he's doing with this specific cam(supposedly) and there's nothing wrong with tune. I'm just going to go with a tune from a different person on a dyno and wide-band.
Old Jan 8, 2010 | 08:28 AM
mark21742's Avatar
I hate to say it, but are a lot of "pro tuners" out there that say they know what they are doing and really don't.
Good luck man, find the right person and they will make you and yor car happy
Old Jan 8, 2010 | 08:39 AM
86MonteSS's Avatar
i have an SI5 cam in my car and i easily get mid-20s on average gas mileage.
if you are in the midwest, take it to speed inc. they'll set your tune straight.
hell, i MAILED them my PCM and i still got 20 mpg.
supersick99z's Avatar
Cam on sig getting about 17 mpg with 250 miles on a tank of gas!
Old Jan 8, 2010 | 08:46 AM
If you want to get rid of that cam I will buy it from you. I think it is one of the best street / strip cams out there, its a real thumper though. It makes great power and torque. Who is tuning your car?
Old Jan 8, 2010 | 09:17 AM
teke184's Avatar
233/233 and i consistently get 24-25mpg highway with the ttops off.
regularly get 17-19 city...lots of short trips.
Old Jan 8, 2010 | 09:29 AM
triche's Avatar
Tsunami Cam here. 235/240 .6XX/.6XX 111 LSA
I get in town on avg. 14-15 mpg because I like to play a little. On the interstate I get 29.X mpg. This is stuffed into my C5 Z06
