can someone explain the difference in dry and wet sumps?
Then a pressure stage then takes the oil from the header tank and feeds the bottom end of the engine.
Advantages are better oil control (like constant oil supply at desired oil pressure and cooler oil temperatures)
Wet sump keeps the oil in the engine and picks it up by the oil pump and feeds the bottom end, advantages are less weight, easy disadvantages are potentially poor oil control
Mine has a SQP custom dry sump
ATI Custom Underdrive Balancer/HTD Dry Sump Drive
Barnes 4 Stage Dry Sump Pump
Petersen Dry Sump Tank
1. is the oil filter in the red pump, or remotely located somewhere else?
2. is the silver pulley your UD puller, or is there another piece to that?seems VERY small for a crank pulley?
3. seems like there is a bit of slack in that belt, is there a tensioner for it?
4. how much does a setup like that cost, and do any of the sponsors to the right sell something like that?
Chris Straub
Stef's Performance Products
