No Oil Pressure Help!!!
Old Dec 19, 2003 | 09:33 AM
blacktransam's Avatar
Default No Oil Pressure Help!!!
heres the senario. we put the new heads cam timing chain the whole deal. we put it all back to gether and i'm getting no oil to the heads. now i broke my oil pressure sending unit off(i'm trying to get a new one) but still no oil up top. I replaced that damn o ring but still no go. i'm buying a new pump and oring today and crossing my fingers.
Old Dec 19, 2003 | 10:30 AM
Slowhawk's Avatar
LS1Tech Sponsor
If you used a doulble row timing chain,check the spacers ,that they are installed correctly.
Old Dec 19, 2003 | 10:37 AM
Shinobi'sZ's Avatar
When you replaced the timing chain you probably put the oil pump spacer in backwards...it is easy to do...if it is not your Oil Pressure Sender than you the Oil Pump Spacer is probably your problem...it leaves a space (if installed backwards) between the block and the spacer and oil simply returns to the pan...hence no oil pressure...I have seen it happen to more people than just myself. Good Luck.
Old Dec 19, 2003 | 01:55 PM
we din't change the crank sprocket for the timing chain . and what spacer might you be referring to and no it's not a double roller
Old Dec 19, 2003 | 02:38 PM
strokedls1's Avatar
If you had a double roller they use spacers for block clearance on the oil pump passages. If the pump doesn't seal to the block you won't have pressure. obviously this isn't your problem if you dont have a double row timing chain.
