etp head question
Old Jan 8, 2010 | 03:11 PM
venom99's Avatar
Default etp head question
does any one have info on what rockers i can use with the 225 head i seen jesel makes them for 1900 a set i got the stands that etp sells but need rockers now asap for these
Old Jan 8, 2010 | 03:54 PM
Reaper SS's Avatar
If you have the ETP pedestals then you can use stock LS1 rockers or do like i did and order a set of Comp Cams part # 1509
Old Jan 8, 2010 | 04:39 PM
venom99's Avatar
ok thanks for your help that info helped me alot
Old Jan 9, 2010 | 09:04 AM
Reaper SS's Avatar
No problem good luck with the setup BTW you are probably going to need a set of 8.150 pushrods also but you got to check that once you have the rocker arms figured out.
Tommy
