LS7 cam in LS1?
Old Sep 13, 2010 | 10:24 PM
1Ls1's Avatar
but if you still want to sound stock/sleeper, you would go with the ls7 cam...correct me if im wrong.....
Old Sep 14, 2010 | 12:56 AM
ae13291's Avatar
so people with stock LS1 cams can upgrade to a factory 1.8 ratio rocker arm from the LS7 motor? i have heard needle bearing failures on the LS7 rockers tho
Old Sep 14, 2010 | 01:00 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I'm not telling you you're wrong, but that isnt the way to go about it. I would again, do the custom route. Have a cam ground with less positive overlap and it will have a sleeper side to it. The LS7 cam is designed for a 427 not a 346. In essence it would be a stroker motor cam.
No reason to upset the rocker geometry. Just do the CHEAP trunion upgrade to the stock 1.7's. If you are looking for more power don't try and get it from upping the ratio. Swap the cam out and keep stock geometry.
Let this thread die!
