Rocker Torque Sequence
Old Jan 10, 2010 | 05:21 PM
BlownChevySS's Avatar
Default Rocker Torque Sequence
Do I have to set #1 at TDC and follow the sequence from there, or can I just leave it all as is and go 22 ft/lbs all around? I have found mixed opinions on this, so if someone can clarify I would appreciate it. Thanks.
Old Jan 10, 2010 | 05:44 PM
muayyadf1's Avatar
Just torque them all then rotate the engine and check twice..
Old Jan 10, 2010 | 05:58 PM
MattysTA's Avatar
X2...same way i did it
Old Jan 10, 2010 | 07:02 PM
I didn't rotate the engine. Guess I'll pull the valve covers off tomorrow, turn the motor, and recheck them. When you guys turned the motor and rechecked them, were they all still at 22ft/lbs or did you have to tighten some a bit more?
Old Jan 11, 2010 | 05:09 AM
vettenuts's Avatar
Here is the correct method. The rest are opinions, this is from GM.
