build question...
Old Jan 11, 2010 | 10:08 PM
camaroboy14's Avatar
Default build question...
In april I will be saved up for a build, right now I am leanind toward a 383 stroker,with trick flow heads and cam kit for top end...now I need to know will this set up work,and if so how much would labor be? And will I be able to drive it on the streets. I have a 02 ss with 25k miles its a a4..I am looking to only spend 5k for parts...also will astock built trans hold up?
Old Jan 11, 2010 | 10:13 PM
john.s's Avatar
well what heads and what cam are you going with?...
yes you will be able to drive it on the streets...
and as far as the trans holding up.. ya... as long as you dont ever get on it that much... you're gonna need a new converter as well with a cam...
sure someone else will chim in as well...
Old Jan 11, 2010 | 10:21 PM
The trick flow pac in the summit mag...also the trans I am looking for. A good shift kit and cooler along wit a 3800 stall...I was looking at tick perfomances pac...maybe see what there about..just want a low 11 sec car..
