Com Cam, straught up or degree it
- should I advance or retard it from the stock setting
I have it apart and wonder if anyone has used this cam ? I would rather go small than have a cam that would not perform in the lower end.
RPM range: 1,200 to 6,000 rpm.
Duration at .050" lift: 212/218 (int/exh)
Valve lift with 1.7 rockers: .522"/.529" (int/exh)
Good torque and mid-range power.
Your really not going to make a huge difference with this, Id just install it straight up. Almost all aftermarket cams come with 4 degrees of advance ground into them for you, which help torque.
I just finished a LS6 for my TJ. I retarded the timing by 2 degrees. First start up bent all intake valves.
Just be sure you konw what clearances you have
