Need Help with H/C Package
Old Jan 22, 2010 | 09:49 PM
camaro76_496's Avatar
Default Need Help with H/C Package
Im taking the engine and tranny out to upgrade the tranny and putting a new clutch and refresh my engine. So I was thinking of putting new Heads and cam while I got Everything out!!
Well my problem is I dunno what to get Im Really happy with this Cam ( 230/234 .613/.604 111+1 LSA) But I got a couple of bucks on the side for new heads and cam.
you can Say im between trickflow-PRC-ET heads but as I said I dunno what to get.
My Car is a Weekend car cruising and most of the time on the street racing and rarely on the strip ( you can say I want something MEAN and high HP/TQ)
(My mods in the Sig.)
Anyhelp will be appreciated.
Thank you,
Old Jan 23, 2010 | 03:02 AM
InsaneDomestics's Avatar
I'd Get A Set Of TFS 220's And Get Ahold Of The Guys @ VA Speed To Spec You A Cam
Old Jan 23, 2010 | 03:25 AM
lemons12's Avatar
That cam is plenty big enough to make a nasty street car.. I would just look into matching it with a nice set of heads.
Old Jan 23, 2010 | 03:30 AM
Ok... any recomendation for heads?
Old Jan 23, 2010 | 03:32 AM
lemons12's Avatar
Depends on your budget.
The new PRC heads (same ones on the record holding ms4 car) are a killer head for the price and will be what I go with when I have the money to upgrade from my current ported heads.
EDIT: You will easily see 470+Rwhp with that setup.. I would shoot for 475Rwhp and anything extra will be icing.
Old Jan 23, 2010 | 03:35 AM
I was thinking between PRC 215s, PRC LS6 stage 2.5, TFS 215 CNC and the ET Heads 215s
Old Jan 23, 2010 | 03:50 AM
lemons12's Avatar
Personal choice is the PRC 215s.
Old Jan 23, 2010 | 03:56 AM
I Would Go With The TFS 215's They Flow Better Than The Others You've Mentioned. I've Heard Some Bad Things About The PRC's Also.
Old Jan 23, 2010 | 10:20 AM
Anyone else would vote for heads???
ET HEADS, New PRC 215s , PRC LS6 stage 2.5, TFS CNC 215s ??? Or if u got something in mind let me know
Old Jan 23, 2010 | 11:05 AM
99blancoSS's Avatar
Plenty of good heads out there, this is a budget choice. AFR, TFS, Edelbrock, All Pro, PRC, Dart (leave any out?) and then a whole slew of cnc'ed OEM heads.
AFR 205 would help with the low end and mid range of that cam and to be honest if this is just a 346 cid then it would be one of the better choices.
If I was saving money I might go to the PRC 5.3's.
Old Jan 23, 2010 | 12:36 PM
wytry's Avatar
PRC 215's or TFS's if you've got the cash.
Old Jan 24, 2010 | 08:05 AM
allngn_c5's Avatar
tfs 215. Follow link in sig for a good read on afr vs tfs albeit on a 402 not a 346.
Old Jan 24, 2010 | 05:13 PM
Thanx Everyone, i think I will go with TFS 215s
Old Jan 25, 2010 | 12:03 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
The PRC Stage 2.5 LS6 heads is a good option on a budget.
If your thinking about spending a little bit more on a aftermarket casting then the PRC 215 heads have a lot of advantages over the other aftermarket castings. The PRC heads are stock rockers friendly, and ship with a .675" spring already installed. Most of the other brands require a spring upgrade to go past .600" lift. Combine the extra cost of the spring upgrade, and a set of $500 rockers & your could have almost purchased a Fast intake & PRC heads for the cost of the other aftermarket casting heads, spring upgrade, and rockers!
http://www.texas-speed.com/shop/cate...MID=1&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jan 25, 2010 | 12:51 PM
allngn_c5's Avatar
There just needs to be a 215 heads battle so a winner can be claimed as far as hp goes and then leave it up to the consumer to decide if they want to run a head that requires a set of YT's or HS's. TFS vs PRC vs AFR. It would kick *** to see all 3 heads tested on the same dyno, same day. Then the curves could be evaluated as to who makes the most low end, mid, and peak numbers.
Old Jan 25, 2010 | 08:51 PM
lemons12's Avatar
Pretty sure TSP did that already....
https://ls1tech.com/forums/drag-raci...rd-9-66-a.html
Old Jan 25, 2010 | 09:15 PM
allngn_c5's Avatar
2 problems lemons. That link doesn't lead to any comparison. Another problem is even if it did the afr 215's weren't out.
Fail !
Old Jan 25, 2010 | 10:19 PM
lemons12's Avatar
Fail !
Was funny though!
PRC 215s have proven their worth for the money... Better or not, who knows... But worth the money no doubt.
Old Jan 25, 2010 | 11:00 PM
allngn_c5's Avatar
Was funny though!
Yes it was funny. I'll give you that much. I'd still like a real comparison. All done on the same car, same dyno, same day. Track performance and street driving are way different. Cars are totally setup different. My car will trap 130 if I can ever make it down the track in good air without breaking. Also can be driven from Michigan to Florida and expect 27 mpg roughly. Not sure some tweaked for the track PRC 215's would cut it.
Old Jan 25, 2010 | 11:45 PM
SOMbitch's Avatar
Well.... First of all they don't make thr ETP's anymore so good luck there. Carey has started a new co. but I would have to search to find out the name. He made a great head though and I am still kicking my own *** for not getting a used set I had a chance to pick up fairly CHEAP. TFS and AFR are both topnotch and you will be happpy with either. Just search around and see what suits you best....
