new bare iron block, what machine work required?
Old Jan 22, 2010 | 10:55 PM
general23cmp's Avatar
Default new bare iron block, what machine work required?
If I order a new, 6.0L bare iron block, what machine work would be required prior to installing bearings, pistons, etc.? If I am not mistaken, they aren't even a 4.000" bore yet when purchased bare, but I might be wrong.
Old Jan 23, 2010 | 12:48 AM
helicoil's Avatar
Default blockwork
They ain't perfect from the factory, so it depends how nice you want it and how much money you want to spend on it.
Probably figure a line hone (if using ARP's, maybe even if you are not), bore, torque plate hone, and a sqaure deck. Might as well figure a set of cam bearings in there as well, as they will have to be removed for the work.
I would not run the 4.00" bore they come at for a performance oriented build. You will need to go a minimum 4.005"
Old Jan 23, 2010 | 01:09 AM
InsaneDomestics's Avatar
Go With A 4.030 Bore And Build A 408
Old Jan 23, 2010 | 08:47 AM
malibutwins's Avatar
buy a used block have it machined and save $
Old Jan 23, 2010 | 09:03 AM
I dont think they come straight from the factory at 4" bore. I believe they are 3.98". If that is true, they could be finished nicely at 4".
Old Jan 23, 2010 | 09:46 AM
SweetS10V8's Avatar
That would be a complete waist. Why would you want to bore .030 out on a perfetly good block?? Hone it to whatever the piston your using needs.
Old Jan 23, 2010 | 10:28 AM
99blancoSS's Avatar
boring it 30 over is not a waste. You still have plenty of room for cleanup.
Old Jan 23, 2010 | 06:46 PM
If You Already Have The Pistons, Rods & Crank Then I Could See It Bein A Waste But If Your Just Starting With A Block And Don't Have The Rotating Assembly Then Why Not Get The Extra Cubes?
Old Jan 23, 2010 | 08:16 PM
johnster's Avatar
so is a 6.0 a 4 inch bore from the factory or not?????
Old Jan 23, 2010 | 09:16 PM
bww3588's Avatar
it's really close. Mine spec'd out between 3.998 and 4.002 on the cnc machine. They aren't even useable by any performance standards. It will need atleast a hone.
Old Jan 23, 2010 | 10:15 PM
99blancoSS's Avatar
Helicoil nailed it, this is why we offer a 403 instead of a 402
bore and hone, line hone, decked. You can't skip on steps, check out his build thread. Very nicely done.
Old Jan 23, 2010 | 10:30 PM
hammertime's Avatar
Because the difference in power between 364 and 370 cubes, or 402 and 408 cubes is minimal, and you are reducing the number of subsequent rebuilds. If you have the means, then go ahead and bore it out, but most people want more than one potential rebuild left out of a new engine.
Old Jan 23, 2010 | 10:33 PM
When you deck the block, does it require adapters or anything for the intake to bolt in properly?
Old Jan 23, 2010 | 10:41 PM
2000TransAmWS6's Avatar
on my 6L block i just had it bored for bigger pistons, new cam bearings installed, and had the block cleaned.
Old Jan 23, 2010 | 10:48 PM
99blancoSS's Avatar
Are you insane? People take those blocks out .060. HKE has a 414 right now that started as a 402 years ago !!
Old Jan 23, 2010 | 11:27 PM
^ Well At Least Someone Is On The Same Page
Old Jan 24, 2010 | 12:59 AM
hammertime's Avatar
Is there really that much difference in 12 cubic inches, with all other parts (heads, cam, and within reason compression) being the same? For a stout street engine, the compression differences between a 402, 408 and 414 would be minimal, based on available octane. Lets say the 402 puts 1.25hp per ci to the rear wheels, or 502.5 rwhp. A comparable 408 makes 7.5 more at 510; a 414 would make 15 more at 517.5 rwhp. Is it not a good idea to leave room for the block to be freshened up a couple of times to rebuild and extend the life of that engine?
I will say, the consequences are farily low on an oem block that can be had relatively cheap. Does it still make sense to bore an expensive aftermarket piece out to the max bore for the first build?
Apologies to the original poster if I have strayed too far
Old Jan 24, 2010 | 12:01 PM
bww3588's Avatar
the block in question is a factory oem block that can be had for cheap.
Old Jan 24, 2010 | 12:38 PM
99blancoSS's Avatar
Max bore is not 30 not sure why you think that? Not even close. There is plenty of room for multiple cleanups (depending on the extent of the damage of course)
We leave room plenty for cleanups unless the customer wants a specific displacement.
402 or 408 ?? Your splitting hairs at that point I agree. 370? well people throw thousands of dollar to chase a few extra ponies, the cost of a crank is minimal when you look at the big picture. Your stock crank needs to be magnafluxed and polished , you don't just stick it straight back in. So depending on what crank you use a 408/402 could be as little as $300 more than a 370 and all things being equal the 408 should make more power than the 370. Is 47.5 hp ( going by your 1.25/cid) worth $300-$500?
I would have to say yes based on what we see people spend to make 15 more hp.
You can get an iron block from the junkyard fairly cheap, new they are only 750.
You also look at whats on the shelf (pistons) when you build it and decide from there as well.
I agree with you but I think there is more in the block than you think.
Old Jan 24, 2010 | 04:06 PM
hammertime's Avatar
I never said that .030 over was the max, and I do realize that you can build the 414 you listed with a .060 over bore.
How do you determine that multiple cleanups are available above 4.030? I realize that sonic testing would be the only way to know what the max is for a given block. I searched through the catalogs for Mahle & Wiseco and I found pistons for LS applications varied, but 4.000, 4.005, 4.010, 4.030, 4.065 and 4.070 are all available. Oddly, neither one listed 4.060, but I assume Speed Pro or some one else must offer that as well. All of Mahle's & Wiseco's pistons were only offered one size over 4.030, either 4.065 or 4.070. I assume custom pistons may be available at sizes in between, but at what cost?
I get that there is no replacement for displacement. My point earlier was to ask what is the difference in power between similar engines with a 4.005/4.030/4.065 bore and a 4.00 stroke - not the difference between a 370 and a 408. If the economic difference between 370 and 408 is only $300 - $500, that too is a no-brainer, much the same debate as 355 vs. 383 on a Gen I SBC.
For the original poster, my only point was why bore a virgin block .030 over and leave possibly one rebuild on the block? Is that worth 7 hp? Is maxing out the bore worth another 7 hp over that, knowing that you would have to purchase another block and start over if a ring land broke or a valve dropped?
