So my horsepower seems to be missing....
Is it that more accurate to have the wideband in a bung welded on the header? Seems like it would only register half the air or something, i know the motor should be the same on the other side....heck...i dont know...
I need to throw in a set of TR55s, gapped at .053 and up my timing back to 33* +/- 2* and run this bad boy so I can get an accurate read on its NA ability.
Let us know how it works.
Charlie.
I want to try to get a few of these things tracked down before I go dyno again. I still think that I should have seen more hp gain by adding 7*-8* of timing though...maybe thats gap related too....
You will see very nice gains once it is leaned out some!
1 - 170 - 175
2 - 190 - 195
3 - 180 - 185
4 - 175 - 180
5 - 180 - 185
6 - 175 - 180
7 - 180 - 185
8 - 175 - 180
So they all seem to be pretty good. The main reason I wanted to compression test, was to see if I could find a reason for this next part...
I didn't post about this before, but I was catching a fair amount of water in my catch can. It seemed to have a orange tint to it, but that could have been condensation with some oil vapors mixed in. Although from checking the water level from time to time, it would be a little low, so I would refill it, then it would be fine for awhile. So the other day I decided to clean out and completely empty the overflow resevoir incase it was pulling water from there. It has been empty for 4-5 days now, and the water level is down just a bit. I am going to keep watching it for a few days to see if it keeps getting lower. There is a little more in the catch can. I emptied it out before into a glass jar. It didnt seperate as well as I thought it would if it were all water and oil. This water doesnt smell so much like antifreeze, or oil, but more like exhaust gas...??
I know its possible to be burning the water off somewhere. I had a buddy that had a small pinhole though one of this ports into the water jacket, and it would lose water there. I am wondering if I am having the same problem. I guess I need to have the cooling system pressurized to see if it is losing it somewhere....
