test trial heads...
Here's what I got. 00 Z28 M6 41k stock internals,ls6 intake,mac headers,true dual x-pipe,whisper lid,160 stat,tb bypass,bellow,ngk.
RWHP 360.0
RWTQ 360.4
I need some help finding a cam for this application. If the heads don't work no harm done, but if they do, can't wait to see the results. Thanks for the help.
A GM hot cam might be an interesting place to start. For something a bit larger, but still safe on the lift, a Comp XR281 should work...
Phillip
info please......
Now for a Cam I would go with a smaller intake duration to help P/V clearence unless you are notching the pistons.
Maybe some thing like 226/234 XE lobe .575/.590 lift on 112.
Jason
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Slowhawk that sounds like something that will work. A 5.7 lift intake was kinda what i was thinking, but if i can go bigger 231/237, and still have the clearance, its on....
Didn't mean to imply it wouldn't work, it just isn't an optimum use of the design given the engine size.
Right on the money!
Bigger ain't necessarily better!
Ed
If you had these heads, what cam would you go with? dur.lift.lsa
