test trial heads...
Old Dec 25, 2003 | 11:57 AM
99 Black Bird T/A's Avatar
Did you measure the P to V with the stock cam? Might help in figuring out how much P to V there is for other applications.
How much P to V safety margin do you want? You might run a 224 with .100 in P to V but a 230ish might cut that too .050 or so.
Set ups vary. My T/A only has .075 P to V with 2 degrees advance with a 224 cam.
Old Dec 25, 2003 | 09:55 PM
drew-00-ls1's Avatar
Yea, what kind of lift though.
Old Dec 25, 2003 | 10:19 PM
LASTLS1's Avatar
6 Second Club Moderator
Put the G5X3 in it! I happen to have a set of brand new diamond pistons with reliefs in them! Then it will clear no problem. Good luck.
Old Dec 28, 2003 | 10:04 PM
Default TSP help me out....
Ok I decided I was going with the 231/237
Can I get by with a .575 lift intake?
I was thinking a .575/.585 lift on a 112 or 114 lsa.
Is a 112 too much for daily driving?
The custom tuning for your cams, is it a mail in, or and upload for edit, how much extra?
other insight welcome....
