402ci. LS results from Trick Flow
[IMG]
[/IMG] Last edited by TrickFlowTech; Jan 25, 2010 at 09:59 AM.
Awesome heads !!!
I am doing one very close to this right now. Hard to beat these heads out of the box, area under the curve, up high at peak, really anywhere.
Would more compression, a ported intake, and hand worked heads have helped? No doubt it would have made more power and torque. What we wanted to do was build a very attainable engine that anyone can build and show the results the “average guy” can achieve with out of the box parts.
GMHTP did a great installation article on our LS2 top end kit. A link is here:
http://www.gmhightechperformance.com...wap/index.html
Their test car with our top end kit ended up running deep in the 11’s at almost 120 MPH. Not bad for a stock shortblock in a full weight GTO
When its time to freshen this motor up I'd like to set it up for FI and run a set of unmilled tfs 235's. Thats going to be a future project though. Awesome line of heads !!!
Take the OP's post and add compression, proper cam and what do you get? Probably another 40+ flywheel hp and a significant increase in TQ as well.
Remember this is a setup that "ANYONE" can do, not just Tony Mamo. BTW don't you have nearly 3700 into your "special" afr 215s ?
Please re-read the post-a magazine did not cover the buildup. It was done at Trickflow on one of our two superflow 901's. We dyno test every product we sell, and also put every product through a 40 hour SAE durability test at varying load and throttle.
The magazine buildup was by GMHTP, on a stock LS2 shortblock. Very different stories but good data none the less.
Having two dynos in house allows us to supply customers good data on various combinations we test. For example, we have test data on our 205, 215, 225, 235 heads on various combinations ranging from a stock 5.3 to a well built 440 CID that makes nearly 700 Hp on pump gas.
If you have any other questions, please let us know.
Al
Thanks for recognizing that. A lot of people don't realize how important, or expensive, owning our own dynos is or what having two full time, very talented dyno operators costs. To us, it is an essential part of doing business.
Thanks!
Al
They would be a few percent lower but in all honesty most flywheel (engine) dyno numbers are quoted with the STP correction factor.
Much like the norm is for the chassis dyno stuff to be quoted SAE, its just the opposite with flywheel numbers.
All the numbers I post from any of my flywheel dyno sessions (including the recent 215 AFR results) are using the same correction factor (STP).
-Tony
Nice work trickflow, made good #'s w/o being optimized.
